Xerox WorkCentre 7120 Factory RESET
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    We have customer with this 7120 that picked up this machine from another service provider and they are having problems beyond what can be explained. We are looking to help them out by simply reseating the machine to factory settings.. Looking for either NVRAM initialization or anything that will wipe it clean as NEW. Please let me know how this can be done via Service Mode. Thanks in advance for al l your help
  • Exok
    • Jun 2011
    • 750
    Re: Xerox WorkCentre 7120 Factory RESET
    Procedure
    1. Enter UI Diagnostic mode ( Accessing UI Diagnostics). Select Initialize NVM. Selections for the following 7 subsystems appear:
      • IOT
      • OUTPUT (Finisher)
      • IISS (IIT/IPS)
      • IISS-Extension
      • Input Device
      • Sys-SYSTEM
      • Sys-USER
      • Fault Counter
      Table 1 displays the areas that are initialized for each section.
      Name Description
      IOT The following NVM locations will be initialized:
      • Chain 740 - links 020 through 419
      • Chain 741 - All
      • Chain 742 - links 055 through 079
      • Chain 744 - All
      • Chain 746 - All
      • Chain 751 - All except links 168 and 364
      • Chain 752
      • Chain 753 - All
      • Chain 760 - All
      • Chain 762 - All
      • Chain 764 - All
      IIT/IPS The following NVM locations will be initialized:
      • Chain 710
      • Chain 715 - links 001 through 017
      SYS-System The following NVM locations will be initialized:
      • Chain 700 - links 006, 065 through 070, 088, 116, 122, 127, 128, 147, 164 through 166, 174, 176 through 181, 197, 208
      • Chain 701 - links 912, 917, 924, 929
      • Chain 720 -link 002
      • Chain 730 - links 00 through 006
      • Chain 770 - links 124, 203
      • Chain 780 - links 065 through 068
      • Chain 785 - links 008, 009
      • Chain 790 - links 003, 004, 099
      • Chain 801 - links 104, 204, 304, 404, 504, 604, 704, 804, 904
      • Chain 802 - links 004, 104, 204, 304, 404, 504, 604, 704, 804, 904
      • Chain 803 - link 004
      • Chain 810 - links 002 through 019, 038 through 127
      • Chain 820 - links 003, 007 through 009, 017 through 019, 024, 026, 027, 029
      • Chain 823 - links 001 through 005, 008 through 011, 030 through 047
      • Chain 830 - links 001 through 004, 084, 085
      • Chain 850 - links 001 through 004, 007, 009 through 012, 015
      • Chain 860 - links 009, 013, 020, 025, 031, 032
      SYS-User All user settable NVM locations in the following chains will be reset:
      Chains 700, 780, 785, 790, 800, 801, 802, 803, 804, 805, 806, 810, 820, 823, 830, 840
    2. Select the subsystem to be initialized and select Start.
      CAUTIONAll NVM for the selected subsystem will be reset to the default values. Any machine-specific, region-specific, or customer-specific information will need to be re-entered. Make sure that this information is available before proceeding.
    3. A confirmation message appears. Select Yes.
    4. A message indicating completion will appear.
    5. Select the Confirm button.
    This completes the initialization. Remember to re-enter any machine-specific NVM data.
    NOTE:
    As-shipped defaults can be re-entered using the Batch Write feature in the PWS Download Tool. Refer to dC351 for details.
    • adriansto
      • 2387
      You need 7120 service software download tool for factory restoring !
      • gerryhuerta
        AccService
        • Jul 2009
        • 198
        This will work. Thank you both
        • padrino976
          Originally posted by Exok
          Procedure
            • IOT
            • OUTPUT (Finisher)
            • IISS (IIT/IPS)
            • IISS-Extension
            • Input Device
            • Sys-SYSTEM
            • Sys-USER
            • Fault Counter
            Name Description
            • Chain 741 - All
            • Chain 744 - All
            • Chain 746 - All
            • Chain 752
            • Chain 753 - All
            • Chain 760 - All
            • Chain 762 - All
            • Chain 764 - All
            • Chain 710
          NOTE:
          hello, i'am italian boy, help me! yo have msn or skype? my contact is silvius2001@htmail.com thanks, help me!
          • padrino976
            Procedure
              • IOT
              • OUTPUT (Finisher)
              • IISS (IIT/IPS)
              • IISS-Extension
              • Input Device
              • Sys-SYSTEM
              • Sys-USER
              • Fault Counter
              Name Description
              • Chain 741 - All
              • Chain 744 - All
              • Chain 746 - All
              • Chain 752
              • Chain 753 - All
              • Chain 760 - All
              • Chain 762 - All
              • Chain 764 - All
              • Chain 710
            NOTE:
            hello, i'am italian boy help me you have msnor skype? my contact is silvius2001@hotmail.com , help me thanks
            • dbhelix
              • Oct 2024
              • 7
              The link seems to be broken for accessing UI diagnostic mode, not sure if its relevant for me if it hangs on startup. I would very much appreciate the "real" technical manuals for this copier as opposed to the useless user and service manuals. If anyone can be of assistance please PM me, I have a specific error code and it hangs on start up at 3/6 I would like to understand low level firmware update procedure as well as factory reset. Thank you
              • adriansto
                • 2387
                What is the error code?
                • dbhelix
                  • Oct 2024
                  • 7
                  It come by it after powering it while pressing the "Start" and "energy saver" buttons. It sits in some --Boot Mode-- LongDiag Mode. All the buttons flash continually and then it tells me PLEASE REBOOT 116-317
                  It seems like that mode is prompting me for some sort of navigation to perhaps select a mode but no buttons manage to do anything.
                  • adriansto
                    • 2387
                    This is procedure from service manual:
                    116-317 = An error is detected when the ESS ROM ESS ROM DIMM was checked.
                    1 remove and insert ESS ROM DIMM
                    2 Check the software version of the controller - update or reload software.
                    3 Replace ESS ROM memory DIMM
                    4 Replace the ESS pwb. ( electronic board )
                    Bulletin from field tehnicians tell to replace ESS pwb pn 604K58590​
                    • dbhelix
                      • Oct 2024
                      • 7
                      So I just want to make sure I understand. The procedure is to Reseat the DIMM module. Is there a different more specific DIMM module that is separate from the obvious one when you open the panel to reveal the hard drive. There are two DIMM Slots. One of which is empty. Removing the module and trying to start is unresponsive, because well, no Ram. I did try to reseat it to no avail. What does ESS stand for?
                      So my understanding is,
                      1. Reseat the obvious ram chip
                      ---Done, didn't help
                      2. Update or reload Printers firmware
                      ---Found latest update but specific update procedure eludes me, attempted putting the .bin file in the root of a thumb drive and booting in various different key combinations, no luck
                      ---Found something that mentioned putting in a very specifically named folder, no luck
                      ---unable to access software updates most guides allude to because no access to the GUI as it hangs on 3/6 of initialization
                      ---Seeking specific low level flashing procedure
                      3. Completely replace the Ram with a new one
                      ---Seems strange to me that it would be a faulty ram chip if it powers on and hangs, seems to have ram available to tell me things, but I could understand perhaps bad portion of the ram chip but I would expect it to crash at random times if that were the case
                      ---Wondering if perhaps ESS ROM memory DIMM is distinctly different from the obvious DIMM on the board
                      4. Replace ESS pwb
                      ---This to me says to replace the motherboard that is responsible for the entire operation of the copier. Do I have that correct?
                      Thank you for your time and effort, please let me know if I am misinformed and where I can go from here
                      • adriansto
                        • 2387
                        Yes there are two slots for DIMM. The white slot is for Postscript DIMM option and probably it is empty. The black one is for memory. 1 and 3 steps from procedure reffer to this DIMM - first ask to reseat then to change. The usb procedure for reload software presume the firmware on the ESS board is ok. If not the reading from usb not works. The procedure for reload the software is for xerox tech with special software which is on he ( or she ) laptop.
                        Last step - to change ESS also requires presence of xerox tech because must done some procedures. Yes ESS pwb si the electronic board where the DIMM and HDD and ethernet, usb serial ports are in place.
                        • dbhelix
                          • Oct 2024
                          • 7
                          Thank you for your help, not to diminish the years of experience or training that a xerox tech must endure but I am more than qualified to follow the same procedures they do. I appreciate xerox has a need to make money but I strongly believe in my right to repair the things I own. So am I to understand this software on a technicians laptop is PWS correct? It is possible without too much trouble to get a laptop set up in this fashion? I’m interested in learning everything I can so any “technician materials” you could provide or point me in the direction of would be greatly appreciated. If you could just confirm for me the laptop and pws is possible I should be able to find procedures, now that I know what I need to do but if you had recommendations for resources for that as well I would not be mad at you. I would sooner replace firmware than the motherboard as it’s a matter of monetary resources. However I will look into the cost of a replacement dim. How universal are the DIMM modules between similar copier modules. Are they standard modules or proprietary?
