Error code 041-366 pls help Thank You , i have change PWBA MCU and PWBA EVE together , but still show 041-366 when start machine afther made few copier . is it have to try POWER SUPPLY ?
DocuCentre II 2055
Re: DocuCentre II 2055
replace mcu eprom and perform NVM IOT initialization should recover the machine.at last perform billing matching
do not replace mcu and ess pwb at the same time it will caused billing matching problem . -
i already solve this problem only change the Drum cartridge assy , is maybe cause by Drum or Drum chip , because i use compact Toner , Drum and Drum Chip .Comment
