xerox docucolor 240 error code 024-958 through bypass tray
  • copycorner
    • 30
    [Error Code] xerox docucolor 240 error code 024-958 through bypass tray
    I can't get the bypass tray to recognize the right size paper. I switched the bypass tray with another machine and the copier will still not recognize the right size paper. Sometimes it will work with 8 1/2 x 11 feeding the short edge first for a couple sheets, then goes back to not recognizing the paper it just fed.
    Any suggestions?
    Randy
  • Exok
    • Jun 2011
    • 750
    Re: xerox docucolor 240 error code 024-958 through bypass tray
    I think that is a communication error. I would start at the connector where the bypass plugs into, inspect for damage, loose pins and then follow the harness back to the board.
    • copycorner
      • 30
      Thanks, I think you're on to it. I'll try to trace it back.
