Error Code. 005-199
  • Reeves
    • Apr 2012
    • 296
    [Jamming] Error Code. 005-199
    I have a xerox wc 5222 jamming on the DADF with error code 005-199 please assite
  • dorez
    • Feb 2013
    • 73
    Re: Error Code. 005-199
    The system detected a document with the following length in the slow scan direction:
    Simplex Mode: 672.4mm or longer
    Duplex Mode: 480.1mm or longer.
    Check the paper size and make sure it is correct, if good then check transport roll for wear and and paper powder clean/replace if necessary. If all else replace the DADF PWB.
    Hope This Helps..
