Phaser 36/4600 and phaser 6500
  • aabarnes1
    • Mar 2009
    • 620
    Hi Guys
    We've just started a large rollout of 300 plus of these models, following an intensive online training schedule for all our techs. I was just wondering, are there any known issues with these units that would be advantageous to me, any experience of faults/issues would be greatly appreciated.
    Many thanks in advance.
    Grant me the serenity to accept the things I cannot change.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Phaser 36/4600 and phaser 6500
    Paul@justmanuals.com
    • nilak
      • Aug 2010
      • 72
      For 3600 keep in hand some PL1.3 belt transport -'item 48 ELA unit 3x5' and
      solenoids are prone to stick in actuated position for apparently no reason-
      just shim the pad (rise it) to keep them work without the hassles for replacement.
      4600- no major mechanical issue except ones due to customer interaction. Noisy fuser
      in the past- flat spot on pressure roll, noisy second tray gear shaft- some gears are too
      loosed to get a resonance, random spots on copies is usually due to Drum cartridge, wrong CRUMs also can be found
      If you got a different billing plan pay attention that the plan is set with first cartridge replacement
      Wrong inventory at the beginning will give you a lot of activities.
      The neutral installation cartridge cannot be reused in the machines with billing plan already set.
      650x can rise an error code instead to ask a new toner cartridge. The imaging unit can fail before the EOF.
      Customer Issues with drivers and software could be annoying but this is part of the job.
      • aabarnes1
        • Mar 2009
        • 620
        Hi, could you explain what you mean by 'shim the pad' and thank you for your reply.
