Xerox 252, fault code 042-326 or 042-327
  • Exok
    • Jun 2011
    • 750
    Re: Xerox 252, fault code 042-326 or 042-327
    When you reinstall the belt, make sure the silver reflective patch is to the rear of the machine. The sensor has to "look" at the patch as it passes by it so it should not be hard to locate the sensors "eyes" in the patches's path. A lot of times you can get away with cleaning , putting on a replacement patch, installing an anti-curl kit. But sometimes you just need to install a new belt. If you install a new belt, the patch has a clear plastic layer over the reflective patch. Sometimes the sensor can see the patch through this and sometimes not. I always remove this from the patch when installing a new belt.
    • ruimestre
      • Mar 2012
      • 36
      Hi
      Similar problem hapened to me a couple years ago on my 250
      The Solution was cleaning the sensor of the belt edge learn, on the ibt module, mine had black toner on it (sensor) and the machine was always giving the error.
      A very good clean with careful and it was done.
      Hope it helps
      cheers
      • themountainecho
        • Dec 2011
        • 43
        Originally posted by Tinochka
        Try to cut new silver patch from oracal film, and replace old patch with new one. I did that many times.
        Hope it helps.
        I attached picture.
        Where do you find this film?
        • djwhoo
          • Aug 2013
          • 117
          #19
          By film... Do you mean belt?
          • themountainecho
            • Dec 2011
            • 43
            #20
            Nope, the silver film that another poster mentioned he cuts new silver patches from. Did a quick google search and couldn't find it.
            • ruimestre
              • Mar 2012
              • 36
              #21
              Hi
              Any vinyl sheet silver and reflective like a mirror will do.
              I'm in Portugal any local Vinil dealer can provide such a film.
              But check the sensor positioning of the ibt maybe that's the fault.
              Heres the vinil
              Search on eBay
              Mirror Chrome Vinyl Wrap Silver All Sizes
              Good luck
              Cheers
