Hi
I have a Xerox Workcentre 3045 not faxing or recieving faxes.If its recieving it will ring normal and goes into fax mode then it writes Recieving Fax on the screen after that it say communication fail and gives this error(034-756}.When am sanding fax it also rings the other side then it says sanding then it will say fax fail.Is there someone who have came against this problem and how did he solve it.Is there someone who knows how to reset this machine or someone with a service/Technical manual for this machine? Please i need your help.
Hope to hear from u soon
Best Regards
Dimpo
Best Regards
Dimpo
