xerox color550 error 91312
  • mdm
    • Jun 2009
    • 132
    Good day all,
    I have been working on a xerox color 550 with a 91-312 at power up, replace LVPS that did not solve problem.
    Wanted to know if any one seen this problem. when I popo with front door open then close door after fifteen minutes of popo, machince comes to ready but fault appears when a copy or print jop is sent to machince.
    Please help.
    mdm
  • dorez
    • Feb 2013
    • 73
    Re: xerox color550 error 91312
    Charge K / Preclean HVPS has failed.
    Check the fuse F402 on the AC Drive PWB for an open condition, if not Replace the Charge K /Preclean HVPS. Part# 105E12593
    Problem keeps happening time to replace the MCU PWB! Part# 160K95233
    Hope This Helps..
    • WIWA
      • Mar 2009
      • 97
      Well just in case check for 24vdc at HVPS after that all roads point to MCU PWBA.
      Hope this help,
      Wiwa72 Gonzos build v.1.0
      • mdm
        • Jun 2009
        • 132
        Thanks Guys Fault was HVPS.
        • dorez
          • Feb 2013
          • 73
          Glad I could help! and it works!
