Windows 7 driver for Document Centre ColorSeries 50
  • CopyX
    • Aug 2025
    Does anyone know of a good driver for Windows 7 driver for Document Centre ColorSeries 50 (64 bit) That will allow to select bypass tray? Has a splash FU2 rip
  • CopyX
    Re: Windows 7 driver for Document Centre ColorSeries 50 / Doc 12
    Found a solution that seems to work so far installed a Phaser driver 64 bit then replaced/and renamed the DOC12 PPD file and renamed what the Phaser PPD file was. Now I can print thick 12x18 stock using bypass in Windows 7 to a Document Centre ColorSeries 50 / DOC12
    Seems to work with no issues so far.
    • Jake2o
      • Dec 2007
      • 325
      I made this one myself; It is no certified, but works fine:
      Index of /Printers/Xerox DCS50
      It is 64bit only.
