Altboot problem
+ More Options
Posts
  • Oltus
    • Dec 2012
    • 10
    Altboot problem
    Greetings,
    Does anyone have had problems starting Altboot- softwares(WCPP,WCPS,7556- series) on W7. I have 3 laptops and all of them give the same error when trying to run it: "DriverExtensionIFC"- Connection failed.
    Same error comes everytime and no diagnostics can be received from the copiers. All laptops are 32- bit.
  • Milo Wilson
    • 502
    Re: Altboot problem
    There has been a known issue with altboot and W7. May have to try WinXP version laptop
    • adriansto
      • 2387
      Re: Altboot problem
      Originally posted by Oltus
      Greetings,
      Altboot requires a serial port configured as com1. Probably your usb to serial adapter need that configuration or this is a cheap adapter and need to replace it.
      Also for WC75xx machine family you need a special serial cable to connect.
      • Oltus
        • Dec 2012
        • 10
        Re: Altboot problem
        Hi, we have chosen the laptops so that we do not need any Usb- adapters. Problem is related into running the software, because it does not start correctly. We are currently checking if some update to anti-virus or windows is the reason because with clean installation, everything runs smoothly... with no antivirus or updates run.
        With Xp- there is no problems at all with these cpu's, but that's not a suprise at all.
        • Exok
          • Jun 2011
          • 750
          Re: Altboot problem
          For 75xx machines why not just load the software using a USB thumb drive? Its quick and easy.
          • xcopytech
            • Aug 2006
            • 1794
            Re: Altboot problem
            There is a special altboot for WIN 7 and GSN 11.
            • Oltus
              • Dec 2012
              • 10
              Re: Altboot problem
              Problem has now been solved... main reason was f-secure. Even thought every service was disabled(by "killing") IE still had it's f-sec addon activated. With a script we were able to make everything work.
              • wlellis
                • Apr 2019
                • 4
