docucolor12
  • Sekundes
    docucolor12
    I`ve got a little problem,
    my dc 12 gives me the 10-105 error..i checked the fuser exit sensor and it works, thing is when the paper reaches the transport belts they don`t work.
    what could be the problem? since the belts work when prepping for print starts.
  • technic
    • May 2008
    • 29
    Check if the problem is happening just with letter size ,normal or heavyweight paper, if the machine works fine with 11x17 inches sheet, clean both sides of the belts to avoid this one slips during run. I got the same problem some months ago.
    • Sekundes
      i`ve fixxed it, it was the motor, some chip on the pwb was burned.
      but thx for the info <3
