XEROX 7655 configuration mismatch, diagnostic error 03-355
  • vojinp
    • Aug 2025
    Dear all,
    Please help..
    Few months ago, my wc7655 lost scan function. After some time, every time when I turn it on, he show configuration mismatch, after clicking yes machine restart and I can use it after choosing language, time.. etc.. .counters zero.
    I called a friend, ex Xerox Technician, and he changed yellow battery located in a backcase, on PWB Assembly NVM.
    After that, machine was in a loop, always showing configuration mismatch, after clicking Yes, coming to same point, cant use machine like before.
    Software was 040.033.53260.. With WCCP, I had error 03-355
    We decided to do altboot, to update to latest software, but this didnt solve a case. Only UI was updated, other modules showed old version of software.
    Than we went to force upgrade procedure, downgrade to 040.033.53050, and all modules are now on that version, but I still have same problem.
    Does anybody have idea what to try?
    I am located in Serbia, so spare parts are rare, cant find PWB Assembly NVM 960k27121A to try...
    Vojin
  • adriansto
    • 2388
    Re: XEROX 7655 configuration mismatch, diagnostic error 03-355
    Do you have WCPP Diagnostic Navigator software tool and what version ?
    • vojinp
      Yes I have WCPP
      Tried on winXP platform with ....342 version, and on win7 with ....369
      • adriansto
        • 2388
        Originally posted by vojinp
        Yes I have WCPP
        Ok,
        Use XP version of WCPP and send me at stoadis@gmail.com printscreens of dc100, dc105 and dc108.
        Also on MCU PWB you have a round battery. Measure the voltage on this batt - DO NOT disconnect battery when do voltage measurement.
        • vojinp
          Tnx a lot, will do it tomorrow morning from the office
          Regards,
          Vojin
          • vojinp
            • adriansto
              • 2388
              Sent mail.
              The round battery is on a small pwb on the mcu pwb located at the left hand from net pwb
              But the problem is in dc105 , machine dont know if it is a copier or a copier/printer
              Do you have service manual pdf or edoc format ?
              • vojinp
                Sent mail.
                No service manual pdf or edoc at my side...
                My service technician has it, we were reading together, but dont know what else to try..
                I can ask him for it if needed...
                • vojinp
                  Sent mail.
                  At the end machine is repaired, NVM board was defected.
                  Case solved :-)
