WC 420 image problem
+ More Options
Posts
  • boanda
    • Feb 2011
    • 79
    Please, look the attached picture
    and if anyone know,tell me what is the problem
    P.S.- this happening on print and copy too
  • adriansto
    • 2383
    Re: WC 420 image problem
    Change print cartdrige and clean transfer assembly
    • Exok
      • Jun 2011
      • 750
      The good news is, it looks like the patient will live!
      • savi0r
        • Sep 2010
        • 363
        Same advice here.
        • livewire
          • Sep 2011
          • 608
          Hi boanda,
          Replace ROS Module, PN 062K13011.
          Success!
          • boanda
            • Feb 2011
            • 79
            Originally posted by livewire
            Hi boanda,
            Success!
            A dont have it at the moment, part will come in few days. Im KM tech and need some time to find xerox part, that is the reason for late answers.
            "Change print cartdrige and clean transfer assembly"-client change cartridge,which is expensive, in firm which is working only xerox, that didnt solve the problem,but they charged the part
            • Exok
              • Jun 2011
              • 750
              Ok, I guess i was the only one who thought that looked like a read out from a heart monitor.
              • livewire
                • Sep 2011
                • 608
                The ROS module may be checked from diagnostics.
                Do you have Service Manual?
                • boanda
                  • Feb 2011
                  • 79
                  Now i have, THX to Sama
                  • livewire
                    • Sep 2011
                    • 608
                    Now, enter diagnostic mode:
                    - turn off machine;
                    - wait 5 seconds;
                    - press and hold down 0 button, switch on machine, release 0 button after control panel indicators iluminate.
                    Check ROS Moter.
                    - press 6 button;
                    - press Start (green) button;
                    - press 4 button;
                    - press Start button.
                    you should hear the ROS motor.
                    If you do not hear it, you can change it.
                    Sucess.
