Fault 124-374 - Docucolor 260
  • fatfingers73
    • Feb 2013
    • 219
    Hi chaps,
    Getting the above fault when copying from trays 5 & 6. Machine just stops and doesn't even attempt to copy.
    I've checked the fuses/voltage on the HCF PWB and they're fine.
    Anyone had this?
    Many thanks.
  • adriansto
    • 2392
    Re: Fault 124-374 - Docucolor 260
    What is your machine configuration ? Tray 6 =OHCF ?
    Fiery or Creo ? From tray 1-4 everything is ok ?
    • fatfingers73
      • Feb 2013
      • 219
      Hello,
      Yes it has SRA3 tray 6 with tray 5 joined above it.
      Pretty sure they have a fiery rip. Trays 1-4 work fine.
      Thank you.
      • max2013
        • Mar 2013
        • 54
        this is somthings to do with the firmware ..i have this problem before oh you can try change the mcu ,,,
