WorkCentre 7345 problem with open cover/door
  • jokke
    • Apr 2013
    • 9
  • adriansto
    • 2392
    Re: WorkCentre 7345 problem with open cover/door
    Originally posted by jokke
    Anyone got an ideas? I have of course tried opening and closing the cover several times with no success.
    /joakim
    This is a joke !
    Nice to have service manual if you want to fix that your own.
    • Exok
      • Jun 2011
      • 750
      Open the left door. Look toward the back upper area on the door assembly. There is supposed to be a black plastic door switch actuator mounted there. This part has 2 plastic prongs that stick out and actuate the door switches when the door is closed (the switches are mounted on the machine side). Often times one of these prongs can break off. If one or both of the prongs are broken off of yours, order and replace this actuator (very easy to do, I think its only held in place with one screw). The part # is 011E10711 (Interlock actuator).
      • jokke
        • Apr 2013
        • 9
        Ahh, now I see. You are correct. Thank you!
        /joakim
