Xerox Workcentre 7665
  • Linzi
    • Aug 2025
    Can anyone help with the following error codes please?
    03.331.00
    03.347.00
    77.115.00
    05.122.00
    thanks
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox Workcentre 7665
    03-xxx are communication failures. Make sure you have all the appropriate cables connected, particularly the UI (monitor) cable. They do get bent if left connected during shipment. You may need to remove the back panel and the connectors where the connect to the boards. If its a new Unit someone may have not reconnected them well.
    Good Luck!
    • Linzi
      Thanks for your help !
      Good Luck!
      • JustManuals
        • Jan 2006
        • 9838
        http://www.justmanuals.com
        Paul@justmanuals.com
