WC5222/5225/5230 series supplies question
  • axyun
    • Aug 2007
    • 1323
    I know that the wc5222 series has metered or unmetered toner cartridges but is that the same for the drum cartridges or are drums interchangeable between metered and unmetered machines. I ask beause I need to get 2 drum units and neither old unit is showing a reorder#. I know one machine is using a metered toner cartridge(106R01304) but the other machine toner cartridge is generic and no xerox # on it or the drum unit.Frank/ActionPhotocopy
  • livewire
    • Sep 2011
    • 608
    Re: WC5222/5225/5230 series supplies question
    Hi Frank,
    For part number 106R01394 see here:
    Phaser 6280 106R01394 Genuine Xerox Supplies
    For another machine that has no catalog number of the toner cartridge and the drum cartridge. This means they are starter kit.
    Below is information from edoc number 705P01231.
    101R00434 Xerographics / Developer Cartridge (Standard)
    101R00435 Xerographic / Developer Cartridge (High Capacity)
    106R01304 Toner Cartridge (Photo Black 110)
    106R01305 Toner Cartridge (DMO Sold Toner)
    106R01306 Toner Cartridge (NAXE Solid Toner)
    106R01413 Toner Cartridge (DMO Sold)
    You can also check here:
    Xerox WorkCentre 5222 Supplies and Accessories
    and here:
    Xerox WorkCentre 5225/5230 Supplies and Accessories
    • axyun
      • Aug 2007
      • 1323
      Thank you for that info Livewire. Also, I made a mistake on the toner cartridge that was in one of the machine. It was a typing error and should have been 106R01304. which is metered toner cartridge for the WC 5222 series. It looks like from your information that the drum goes in either machine as the 2 units you mention dare different in yield only(50,000 vs 80,000). Thanks again for your prompt response and useful info. Frank
