xerox printout problem image missing
  • pc123321
    • Dec 2012
    • 103
    xerox wc pro 35 today has the problem printout from computer the image missing
    see the image in the circle
    another problem is error message shown on the screen ,copy and scan unavailable
    machine initialize scaner fail ,but still can output from computer
    any commend are welcome thanks
    see attach file
  • Exok
    • Jun 2011
    • 750
    Re: xerox printout problem image missing
    To me it looks like you have 2 different problems.
    The copy quality issue looks like a transfer problem. Maybe your BTR roller is coming loose on one end? Problem with the transfer belt? Paper is buckling? Might even be a developer problem if your developer inside the DV housing is depleted on one end.
    As far as the scan error, you would need to find out what fault code is being generated. If it does not display right on the screen you may have to look at the fault history or possibly connect to the web UI to see if the error code is displayed there.
    The scan problem can be a number of things from a mechanical problem not allowing the scanner to move (binding , breakage in scan drive) to something electrical (scan lamp, scanner drive motor, sensor, scanner data processing). A fault code would be needed to narrow down the possible cause.
    • pc123321
      • Dec 2012
      • 103
      sorry , this is my xerox wc pro 35 b &w
      1. scaner error code 14-110 it say scaner sensor
      sensor ccd board near j450 connector 3 resistors burn
      scaner error caused any connection with image missing ?
      2. xerox pro 35 drum ok fuser ok toner ok ---developer ?
      • adriansto
        • 2383
        First read the service manual. 14-110 reffers to scan carriage home sensor. Many things to check for this error.
        Second, when you print on the machine, scanner is nothing to do with printing.
        Check if the developer module moves free when you lock /unlock the yellow / orange drum lever.
        What is the lead edge on the posted printing ?
        • pc123321
          • Dec 2012
          • 103
          this is printing from xerox wc pro 35 11 x17 paper tray 1 and by-pass
          paper input on short side 11
          turn on xerox wc pro 35 machine initial , sensor motor noise not move scaner lamp off , initial last step network complete scaner and copy unavailable
          b&w printing first 3 page or 5 pages ok then image missing (mostly upper part of paper),turn off/on again printing first page ok
          but maybe 5 page or 3 page image missing .before that paper jam , we clear it ,image missing , it may happen at (toner to developer) , sometime missing at middle
          • adriansto
            • 2383
            When imagine begin to missing do a panic stop of the copier and check is the image on the drum on the missing zone. Also remove developer module and looks at the magnetic brush, look at the developer gears, try to rotate with hand magnetic roller. The machine is on plane surface ?
            I presume lead edge is where 'Octomber 25,2013 is printed'
            • livewire
              • Sep 2011
              • 608
              Hello pc123321,
              1. About the quality of the print from the attached photos, I think the problem is in Short Paper Path Assembly (059K33981).
              2. About 14-110 error, replace CCD PWB (604K35300).
              Success!
              • pc123321
                • Dec 2012
                • 103
                Originally posted by livewire
                Hello pc123321,
                Success!
                two pics
                left rint 11x17 paper
                right one printout image missing
                • livewire
                  • Sep 2011
                  • 608
                  Yes, about right pictures.
                  I think Short Paper Path Assembly not pressed well Transfer/ Detact corotron to the xerographic module.
