xerox 232 workcenter
+ More Options
Posts
  • ROBIN JENTZEN
    • Mar 2010
    • 12
    customer replaced drum unit and is still getting message to replace the drum unit but the count has reset but not the message is there any way to reset message with out getting new chip
  • Exok
    • Jun 2011
    • 750
    Re: xerox 232 workcenter
    Not that I know of. Maybe they installed an old used drum thinking it was new.
    • ROBIN JENTZEN
      • Mar 2010
      • 12
      they have both units there and I swapped them back and forth still same
      • Exok
        • Jun 2011
        • 750
        In the supply screen, the new drum reads 100% ?
        when you install the old drum what does it read?
        what exactly is the message being displayed?
        maybe its not asking for a new drum because it is old but due to an error/fault
        check fault history / current messages
        also check the condition of the crum connector for breakage or paper stuck in it
        check that the new drum is not defective
        • efe311
          • Oct 2008
          • 114
          Replce nvm
