WC 5020
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] WC 5020
    hello all we have xerox wc 5020...we seeing this error code U2 all led lighting flashing there for toner and developer unity and jammed paper ...please help
    BEST TECHNICIAN . NICE PEOPLE .
  • Blizzoo
    • Aug 2013
    • 608
    Re: WC 5020
    U2-1 Carriage Module Fail
    BSD-Reference: CH6.2 (Figure 2)
    Explanation
    A carriage fault was detected.
    Procedure
    Execute diagnostics [05-22 Move scanner to home position] and [05-23 Move scanner to maintenance
    position]. (How to Enter the Diagnostic Mode) The carriage moves.
    Y N
    Check each IIT Carriage connector. Each connector is connected securely.
    Y N
    Connect each connector securely.
    Check for foreign substances and deformed parts in the carriage. None is found.
    Y N
    Remove the foreign substances and repair the deformed parts.
    Replace the IIT Carriage (PL 10.3)(REP 10.3.1).
    Execute diagnostics [05-23 Move scanner to maintenance position]. When the IIT Carriage
    has moved to the leftmost position, press the [Stop] button to put the Carriage Sensor into the
    blocked state. Execute diagnostics [5-11 Home Sensor], and "H" is displayed.
    Y N
    Check each IIT Carriage and Carriage Sensor connector. Each connector is connected
    securely.
    Y N
    Replace the Carriage Sensor (PL 10.6) and the IIT Carriage (PL 10.3) (REP 10.3.1) in
    that order.
    Check the Carriage Sensor (PL 10.6 ). The Carriage Sensor is installed properly.
    Y N
    Install the Carriage Sensor (PL 10.6) properly.
    Replace the IIT Carriage (PL 10.3) (REP 10.3.1).
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      Re: WC 5020
      Explanation
      Procedure
      Y N
      Y N
      Y N
      Y N
      securely.
      Y N
      that order.
      Y N
      thank you friend ..but all your thread is copy and past from service manuals ...l tell you all this l controlled there ...l need help if anyone have this problems and find the solution ..please ...
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        Re: WC 5020
        other it have some technician friend was said me maybe it have broken exposition lamp ..it's real ?
        • livewire
          • Sep 2011
          • 608
          Re: WC 5020
          Check exposition lamp through diagnostics.
          Have Service Manual, right?
          • JustManuals
            • Jan 2006
            • 9838
            Re: WC 5020
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              Re: WC 5020
              all technician l find my problems and l solve it ..we have broken exposition lamp ..we have sm for this machine .....also we have best friends in our copytechnet
