c2128 network scanning
  • icb
    • Oct 2009
    • 28
    [Misc] c2128 network scanning
    Need help with setting SMB scanning on Xerox c2128. Made a shared folder on C:\scan with full permissions, then thru web interface have set up file repository with ip address of computer, name of shared folder and login and pass info.
    Still, after scanning, machine prints failure report stating that login info was not ok (Im positive login info is ok).
    Anyone can help with this? I have tried two computers, win xp and win 7, in bot cases the problem is the same. Should I rather use ftp protocol instead of smb?
    Help is appreciated.
  • adriansto
    • 2387
    Re: c2128 network scanning
    What's about firewall?
    You can setup a ftp server on your computer and use ftp protocol instead smb potocol
    • seximibabay07
      • Mar 2013
      • 59
      Hello friend,
      do you have WPS Diagnostics tool for
      WorkCentrePro C2128?
      Best regards;
