xerox 5252 problem conection with fiery
  • paws79
    DSC_0047.jpgi have some like this power cabels is not connected and others but all it s connected
    Ok i see
    not good cable conection fiery to xerox ths
  • davidj7
    • 1107
    Re: xerox 5252 problem conection with fiery
    I believe it says Check power and cable?. Could you elaborate on how this problem started?One fine morning you had this problem ?
    • paws79
      i think is problem old cabels i disconected all and do all to new
      • davidj7
        • 1107
        so did you solve the problem. If you can send me a picture of the cables I can check if i have the same .
