Xerox 5687 - PWS Altboot - Linux files and Scanenablement codes needed
  • Majestik355
    • Oct 2012
    • 6
  • adriansto
    • 2387
    Re: Xerox 5687 - PWS Altboot - Linux files and Scanenablement codes needed
    First you must say what software version is on to machine.
    Second - how do you know the NC boot is correct ?
    All four ( 4 ) mesages at the end of booting process appear in altboot window ?
    • Majestik355
      • Oct 2012
      • 6
      All for mesages at the end of booting process appear in altboot window ?
      For system it is 20.120.52.000, I don't know for the NC software. From Altboot with option 1, I see NC is normally booted and arrives to the login line: Xerox5687 login: and the line pasword: after it. I dont know the user and pasword, if I needed to do something more. I'm not sure what 4 messages must be. Thanks.
      • adriansto
        • 2387
        Anastas I sent you email.
        After the lines with user and passwd the boot process must go on. You dont need to type anything.
        • Majestik355
          • Oct 2012
          • 6
          Ok, I'll wait for it. Thanks for the e-card, Season's greetings for 2014 and best wishes to you too.
          • Majestik355
            • Oct 2012
            • 6
            Case solved. Reloaded software via Altboot and there was no need for any scan enablement codes. It reloaded the codes itself during/after software reload and Network controller is now available, connected to machine. Thanks.
