116-399 on docucolor 242
  • adeyemi
    • 378
    Can someone kindly tell me what the Dc242252/260 service manual says about the fault code 116-399. I have only the dc250 service manual and this code is not in it.
    Dgtal
  • adriansto
    • 2369
    Re: 116-399 on docucolor 242
    The error code appear at the power on time or after a while ?
    Machine boot-up or not ?
    • adeyemi
      • 378
      It appears after a long time without booting
      Dgtal
      • adriansto
        • 2369
        How many boot segments appear on UI display ?
        • adeyemi
          • 378
          Its something like three.
          Dgtal
          • adriansto
            • 2369
            Clean the both ends of the flat cable between MCU and IOT and reseat the cable.
            Watch if when you start the machine ( power on ) main motor start. If main motor dont run then check front door interlock switch.
            Or you are unlucky gay and must replace the harddisk PL11.6 item 4
            • Exok
              • Jun 2011
              • 750
              In addition to what adriansto suggested, make sure the finisher has power.
              I've seen a tip that says if the finisher has no power to it, that can cause your code. The finish has its own power cord.
              I've also seen reports that this can be caused by a faulty Low Voltage Power Supply. Check the LVPS outputs.
              • vishop
                • Jan 2011
                • 220
                Worked for me. Thank you
