Xerox 510 AccXES Controller
  • bojans
    • 1313
    I have Xerox 510 DP with AccXes Controller serial number starting: PUN xxxx
    Error E7.01. Seems that HDD gone bad. So I'm looking for software to reload controller.
    Anyone wiling to share\exchange\sell.
  • dorez
    • Feb 2013
    • 73
    Re: Xerox 510 AccXES Controller
    There are 2 possible AccXES controllers for this unit... Which one do you have: 1) Serial Number Starting HFT -OR- 2) Serial Number Starting YKE
    • bojans
      • 1313
      It's starting with PUN. (HTF\PUN )
      • livewire
        • Sep 2011
        • 608
        E7-01 is Communication error:
        The IOT is unable to communicate with the Controller. The IOT Off-Line and Media menus will still function, but cannot print from the Controller or network.
        Go to E701 RAP in Controller Service Manual.
        There are distinct versions of firmware for each controller hardware platform. Firmware is available for the hardware platforms as indicated below. Your hardware platform can be determined by examining the printer configuration test print or serial number (found on the AccXES controller unit). Note your hardware version. Note: Use the HFT firmware as this will be the correct downloadable binary for PUN controllers.
        Controller ---------CPU from Test Print ----------Serial Number
        PUN-----------------RTT-MPC 7410-----------------PUN-XXXXX
        HFT-----------------RTT-MPC 7410-----------------HFT-XXXXX
        • bojans
          • 1313
          I have bad hdd. It's clicking badly.
          • livewire
            • Sep 2011
            • 608
            Understood.
            • technogeek2009
              • Mar 2011
              • 167
              We can sell you the hard drive pre-formatted with 510 firmware, or test / repair your controller. A clicking sound from the HD is a give away though. Contact me directly for pricing. cbyrne@goevergreen.net
              Carl
              • bojans
                • 1313
                Thank you for your offer.
                It would take long time for hdd to arrive to my place.
                That's why I'm looking for software.
                Cheers
                • technogeek2009
                  • Mar 2011
                  • 167
                  Sorry, I just noticed your location. You are correct about shipping time. The files are too large to include here. Drop me an email, I will upload to Drop Box what you need. cbyrne@goevergreen.net
                  • bojans
                    • 1313
                    Problem solved.
                    Thank you all for support.
                    • walidcharifi
                      • Feb 2011
                      • 379
                      hi
                      ihave a problem with hdd of controller HFT 510dp
                      i need software
                      things
                      walidtirage@yahoo.com
                      • Jesgrew
                        I have the same wide format system, with a different problem: Same error code.
                        Our hard drive died, so we replaced the old Dell controller with a Dell 790.
                        We installed windows 7 64 bit and replaced the SCSI card with an Adaptec 29160N card.
                        The old card would not work in Windows 7.
                        The problem we are having is that the SCSI card does not see the printer.
                        Does anyone have an idea of what settings on the card need to be changed?
                        Or do we need to get a VHDCI SCSI card?
                        Thanks!
                        • Corder
                          • Nov 2014
                          • 105
                          Thanks!
                          Emmm... Did you installed win7 on the controller? If so how do you expect your 510 to work with Win7 controller? Because Xerox uses Accxes controllers with OS based on Fedora core and I never heard of 510 controlled by something different.
                          • Jesgrew
                            Well, as I wrote, the 510 had a Dell Optiplex 520 as a controller. So never knowing what OS was installed, we figured the Dell Optiplex 790 would work. SCSI is SCSI, so we figured a newer card would work. Problem is, OS beside the point, if the card can't communicate with the printer, the OS boots after the card., you are dead in the water. That being the case, if there are settings that need to be set so that the printer can connect with the card, what are they? Yes! Great hardware, worked for years, till the HD died. End of the day, if you know what SCSI settings will make this work, post em.
                            The hardware is fundamentally unchanged, and works, Ricoh/Kip/Oce among others sell the same LED system, but this Xerox 510 has issues.
                            If any body has this system, working in a Win 7 environment, please let me know how you got it going!
                            • Corder
                              • Nov 2014
                              • 105
                              My dear friend, if I was you, I'd be worrying about where to get Accxes CD for my 510, new scsi you can buy at any time but it'll never come in handy without Accxes preinstalled controller.
                              And by the way, how you determined that your scsi card isn't working with the printer?
