Docucolor 240/250 bustled Fiery Software
  • InterfaceP
    • Jun 2013
    • 488
    Hello All,
    I'm looking for Docucolor 240/250 bustled Fiery Software. I currently have the CD but need the Software version for USB Flash installation.
    Thanks in advance
  • adriansto
    • 2388
    Re: Docucolor 240/250 bustled Fiery Software
    Why you need this-USB_Flash_Drive_Preparation_v3.21- if you have Software cd ?
    • dorez
      • Feb 2013
      • 73
      are you looking for the usb flash drive making software? This software basically loads the system software on the usb flash... -OR- are you looking for the USB flash drive software?
      • InterfaceP
        • Jun 2013
        • 488
        I need the actual software. I have the USB prep and the Flash tools.
        USB prep wont work on a 240/250 so I need to use the Flash.
        The Fiery on occasion wont take the SW using the CD via a crossover cable. I need an alternate method. I have read that loading via a flash drive is the best way.
        But you cant load the CD onto the Flash drive because it's a Image file. You would need the SW.
        Thanks again for your help.
        • dorez
          • Feb 2013
          • 73
          I have software...
          • adriansto
            • 2388
            USB_Flash_Drive_Preparation_v1.1 wont work with software cd's for DC240 but USB_Flash_Drive_Preparation_v3.21 will works. Your sys software cd for Fiery is version 1.1 or you have three cd's with 1.2 version ?
            • InterfaceP
              • Jun 2013
              • 488
              Only 1 CD its v1.0. I have tried to load onto the USB using USB_Flash_Drive_Preparation_v3.21 but it fails.
              When I try to install with CD via crossover it gives me an "Installation Failed" after step 2 has started. I have two controllers that stop at the same spot when attempting to install??
              • adriansto
                • 2388
                Send mail at stoadis@gmail.com
                • sanimir
                  • 183
                  I have the same problem. I need an installation CD SW 1.2 version with instructions if someone can send. thanks in advance
                  • adriansto
                    • 2388
                    In fact there are three cd's for this software version or a 2GB USB stick with preloaded software.
                    • sanimir
                      • 183
                      there is somewhere for download?
                      • adriansto
                        • 2388
                        I dont know. May be on ebay ?
                        I have version for usb stick.
                        • sanimir
                          • 183
                          how do i get from you
                          • adriansto
                            • 2388
                            Mail to stoadis@gmail.com.
                            But is not for free !
