xerox 8825 I need scanner driver .
  • javier4065
    • Feb 2007
    • 251
    hello, I need the scanner driver for xerox 7346 what programs I must have? and How Should I install it? My compute has window xp and autocad 2010 thanks.I formatted pc and all programs are lost.
  • technogeek2009
    • Mar 2011
    • 167
    Re: xerox 8825 I need scanner driver .
    There are several things you will need. First is the feature key to enable scan to net capability. This has to be purchased and will be tied to the hardware address of the controller on the 8825. There is a Xerox website where you would register the feature and receive the code which must be uploaded to the system. This will unlock the scanning ability of the system. Then you will need to install and configure a free application which is available from the Xerox website.
    We can sell you the feature key and provide you with appropriate installation instructions. If needed, drop me an email cbyrne@goevergreen.net
