Xerox Dc8000 (Code 006-377)
  • lilleputte
    • Jan 2013
    • 153
    Mathias
  • adriansto
    • 2384
    Re: Xerox Dc8000 (Code 006-377)
    Refers to the 5 volts interlock ROS safety switch.
    You can checj left and right interlocks from the front door.
    But also may be a lof of another reasons for this error code.
    Many measurements must be done so you need a service manual.
    • xtrain
      • Dec 2012
      • 233
      Originally posted by lilleputte
      Mathias
      Do you have a PWS laptop? This is required to link up to a Xerox DC8000 and repair faults, especially the 006-377 fault. If you had a PWS laptop, you could repair this problem. I have such a laptop available.
      • lilleputte
        • Jan 2013
        • 153
        Howdy. We have no pws but this sounds really interesting. I'll check if this is of interest to us. I will get back to you =)
        Thanks in Advance
        Lilleputte.
        • davidj7
          • 1107
          Without a PWS laptop dont even think of keeping this machine running for long .
          a machine is only as good as your tech : source:screwtape ; the scary one
          • xtrain
            • Dec 2012
            • 233
            Mathias
            You need a PWS laptop to repair this machine.
