How do I Disable esmart solutions on WC 5675
  • butitsmyfirstday
    • Feb 2011
    • 60
    Hello and thanks for reading. I'm trying to disable esmart solutions on WC 5675 can't seem to find the option in the web interface. Thanks in advance for any help.
  • livewire
    • Sep 2011
    • 608
    Re: How do I Disable esmart solutions on WC 5675
    Try this:
    write smart esolution in the search box and press ENTER.
    #6 How To Disable SMart eSolutions Using CWIS
    • butitsmyfirstday
      • Feb 2011
      • 60
      Originally posted by livewire
      That was actually the first place I looked... It had information for other models that I am already familiar with (wc57xx & wc76xx) The wc5675 appears to have a different interface.
      Just saw your edited post. As I said this is where I went first, the information provided does not apply to the machine I am referring to. There isn't a "SMart eSolutions setup link" nor is there an "not enrolled" radio button
      From a computer, open an Internet browser window.
      Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
      Click on the [Properties] tab.
      Enter the user name and password in the fields provided, and then click on the [Login] button.
      NOTE: The default user name is "admin" (case sensitive), and the default password is "1111".
      Click on the [General Setup] to expand the list of options.
      Click on the [SMart eSolutions Setup] link.
      Click on the [Not Enrolled] radio button.
      Click on the [Apply] button.
      A "Properties have been successfully modified" message will be displayed. Click [OK].
      Close the browser window.
      • livewire
        • Sep 2011
        • 608
        The picture is very small and not see anything.
        What software version is the device?
        Search in HELP of CWIS.
        • butitsmyfirstday
          • Feb 2011
          • 60
          system software version is 21.113.02.000
          • livewire
            • Sep 2011
            • 608
            Try to upgrade Software via CWIS.
            This is System Software version 21.120.52.000
            For each case, make sure that you have everything optional codes such as network scanning, Email and more.
            Then try with How to disable Smart eSolutions using CWIS.
            It happens when the device lost network/internet connection.
            But you have a connection with the device through CWIS.
            UI says it lost connection to the Smart eSolutions server and to contact the system administrator.
            All network settings right? Can you print? Can you scan?
            • adriansto
              • 2392
              If you can't disable SMART eSolutions from WEBUI interface, Properities-SMarteSolutionsSetup-SMarteSolutions Enrollment=Not Enrolled, Then the only choice is to reload machine software using Altboot method.
              • butitsmyfirstday
                • Feb 2011
                • 60
                Thanks for the replies and the firmware link. Is there a way to retrieve the activation codes if they are not with the machine? Thanks
                • dorez
                  • Feb 2013
                  • 73
                  This might help.. Use: (or enter a serial number to get all the keys for a machine) on the link below.
                  https://www.xeroxlicensing.xerox.com/fik/ViewFind/FindFIK.aspx?lang=en-US
                  • livewire
                    • Sep 2011
                    • 608
                    Hi butitsmyfirstday,
                    check here.
                    http://www.copytechnet.com/forums/sh...highlight=5645
                    • igorbirokip
                      • 24
                      Hello,
                      Please is anybody have NVM file for wc 5645 (*.nvb) with (ser.no.) Costumer lose floppy disk, and battery die.
                      I don't have on field this type .
                      igorbirokip@gmail.com
                      • omni
                        • 30
                        To disable esmart solution try to change NVM value in 700-498.
