xerox 5225 error code 016-210
+ More Options
Posts
  • javier4065
    • Feb 2007
    • 251
    I have a problem with this copier. what can I do to solve it? thanks.
  • adriansto
    • 2387
    Re: xerox 5225 error code 016-210
    Put back into machine the device option that is missing.
    Or you can clear all machine options and after that reload the options do you have.
    • javier4065
      • Feb 2007
      • 251
      Thanks for your help .How can I enter to service mode to cancell the hdd options.
      • Exok
        • Jun 2011
        • 750
        Entering UI Diagnostics
        1. At the Control Panel, press and hold the 0 key for 6 seconds, then press the Start button while still pressing the 0 key.
          The CE - Passcode screen will appear.
        2. Enter the Access Number 6789 and press Confirm.
          The colors on the display are reversed to indicate that UI Diagnostics mode is active.
        Accessing Diagnostic routines
        1. Press the Machine Status button on the Control Panel.
        2. Select the Tools tab on the UI.
        3. Under Features column, use the down arrow and scroll to and select Maintenance / Diagnostics.
          Procedure
          1. Access Diagnostic Routines.
            1. Enter UI Diagnostics ( UI Diagnostic Mode).
          2. Select Sub System.
          3. Select Initialize Hard Disk and select Partition A.
          4. Press the Start button and select Yes.
          5. When Partition A has been initialized is displayed, select Confirm
        • max2013
          • Mar 2013
          • 54
          put in the hdd will be ok....
