have workcentre pro 32 with 1% remaining on belt cleaner assembly and transfer roller
  • Rullmann
    [Error Code] have workcentre pro 32 with 1% remaining on belt cleaner assembly and transfer roller
    having hard time finding those parts for this model. any suggestions?
    and is there a code to allow scan to email?
    thank you,
    Mike
  • Rullmann
    Re: have workcentre pro 32 with 1% remaining on belt cleaner assembly and transfer ro
    here is alert screen info
    07-533 Tray 3 is empty. User intervention is required to add paper. Printing can continue if the proper media is available from other trays. Untrained
    04-516 The IBT Belt Cleaner assembly needs to be replaced soon. Schedule Service. Printing can continue. Trained
    04-517 The Transfer Roller unit needs to be replaced soon. Schedule Service. Printing can continue. Trained
    01-550 The machine is currently in Power Saver Mode. No user intervention is required. Printing will start when a job is received from the network or a scan job is ready to print. No Intervention Required
    • adriansto
      • 2387
      You can remove the IBT cleaner and clean it. But is more safe to replace the IBTcleanner assy.
      Transfer roll can be reseted if it's in a good condition but for that you need to enter diagnostic mode.
      The diagnostic mode is not builtin into machine so you need pws tool software for do that.
      For activating scan option you must to insert a chip into back net controller.
      Semd mail at stoadis@gmail.com may be I can help you.
      • Exok
        • Jun 2011
        • 750
        I'd say your best bet would be to place a service call. http://www.comdoc.com/
        Comdoc services your area. I don't work for them, I work for their parent company.
