Error 004 360 DCC 400
  • ck1
    • 485
    may i know what error of this and how to solve it . thanks
  • xcopytech
    • Aug 2006
    • 1792
    could not find such fault cod ein manual
    have only 4-361 and 4-560
    will check on xerox updates
    • ck1
      • 485
      If 4-361 is what happen ? because customer tell not very clear. if this code how to solve it ? thanks
      • xcopytech
        • Aug 2006
        • 1792
        4-361 and 4-560 are codes for drum motor (CMY)
        you have to check drum motor from diagnostic but for that you need xerox pws software and diagnostic software for dcc400.
        this machine have two drum motors, one for CMY and one for K.
        There is no part nubmber just for motor, you need to replace Drum Motor Assembly
        • TechMate
          • Mar 2008
          • 285
          Maybe it sounds like 4-363 (?) If so, check the condition of the K drum and also test the K drum motor. Replace if faulty
