Color Qube 9303 Error Codes
  • IkeW0491
    • Oct 2013
    • 172
    [Error Code] Color Qube 9303 Error Codes
    Hi All,
    I have a Color Qube 9303 with the following error codes showing up.
    092-572 & 094-534
    It will not allow any copying or printing.
    Any info on what these errors pertain to would be helpful .
    I do not have any SM's for this model.
    Also it appears that the paper trays are not lifting and therefore giving a out of paper message too,
    not sure if this is related to 1 or both of the error messages.
    Thanks in advance for any assistance.
    IKE
  • dorez
    • Feb 2013
    • 73
    Re: Color Qube 9303 Error Codes
    Check your Private Messages.
    Originally posted by IkeW0491
    Hi All,
    092-572 & 094-534
    IKE
    • adriansto
      • 2387
      94 code is from drum drive belt ( green one ). Problem is with this belt or drum driver pwb or rear bearing is defect.
      92 code probably is the consequence of the 94 error code
      • IkeW0491
        • Oct 2013
        • 172
        Thanks all for the support.
        It ended up being the Drum Driver belt ( was still black one). It was in tatters and had stopped the drive motor from turning.
        Replaced belt, no further issues.
        I truly thank everyone for the answers and support.
        IKE
        • Exok
          • Jun 2011
          • 750
          If your old drum drive belt was frayed, make sure to remove the drum drive motor and inspect the pulley / drive shaft for strands of the old belt that can get wrapped up around the motor shaft. I've had a number of machines where this happened and I had to cut away strands from the old belt to free up the motor.
          • IkeW0491
            • Oct 2013
            • 172
            Thanks Exok,
            We already did that.
            It took like 20 mins to get all the strands off the pulley!!!
            IKE
