Problems connecting to WC 7775 (TCP/IP)
+ More Options
Posts
  • themountainecho
    • Dec 2011
    • 43
    [Misc] Problems connecting to WC 7775 (TCP/IP)
    Hi,
    I've just bought a 7775 to use as a backup for my aging DC 242, but I cannot for the life of me connect to the printer. When I try to enter the printers IP address on the Config Report in my browser I get a 'Connection has timed out'. I'm assuming this is because it's still setup for the previous owner and has static addressing, but without being able to connect to the printer I don't know how to change this. Any suggestions would be greatly appreciated.
    Config report is attached.
    Thanks in advance,
    Ken
  • Flash
    • 378
    Re: Problems connecting to WC 7775 (TCP/IP)
    You can change the ip address from the touchscreen http://www.support.xerox.com/support...IP_WC7755_Base
    Copy and paste the above link into your browser for step by step instructions or set the machine to DHCP to pull an ip address.
    • themountainecho
      • Dec 2011
      • 43
      Thanks for that Flash, very much appreciated!
