FreeFlow password
  • Gbr
    • Nov 2011
    • 50
    [Misc] FreeFlow password
    Hello
    I have a xerox DC260 with freeflow print server, which i want to connect to my network, but i can't log on (on server).
    It gives me option for user :
    User
    Operator
    System Administrator
    I tried with password 1111, 11111 and 22222, x-admin, and no password
    it always says user not found.
    It is the first time i am dealing with xerox and at least i want it to set printing but network configuration is greyed out.
    Can I somehow restore passwords ( i don't have any PWS), or can somebody point me to right direction (:
    Any help would be much appreciated
    Thank you very much.
  • xcopytech
    • Aug 2006
    • 1792
    Re: FreeFlow password
    try admin
    • Milo Wilson
      • 499
      User: System Administrator, password is: administ
      • Gbr
        • Nov 2011
        • 50
        Hello
        I tried with that and still prompts " user not found "
        I have found list with many diverse usernames and passwords for different xerox print servers and nothing works.
        Thank you for replying!
        • Gbr
          • Nov 2011
          • 50
          To be clear
          i can log in trough machine control panel(key button- system administrator login - 11111) but there is no network configuration.
          I hooked Print server with monitor and keyboard. i will paste few screenshots.
          Thank you again.
          • Milo Wilson
            • 499
            If you selected System Administrator and typed administ in lowercase and it didn't log in then someone changed it from the default. You will have to reload software to get it back to default. make sure to copy the license strings down before you do that.
            • Gbr
              • Nov 2011
              • 50
              ok, thank you!
              This is not it, is it?
              Can that be done trough CD drive or I probably need PWS for reloading software?
              If PWS not needed - is there any manual how to do this.
              Thank you !
              • adriansto
                • 2383
                Can you open a Terminal Window on the server ?
                • Gbr
                  • Nov 2011
                  • 50
                  yes
                  • adriansto
                    • 2383
                    Originally posted by Gbr
                    yes
                    Send me a mail at stoadis@gmail.com
                    I will send some instructions to try for recover the passwords
                    • azehnali
                      • Nov 2009
                      • 679
                      your liscence string are expiring also
