xerox workcentre 5020 n9 error
  • javier4065
    • Feb 2007
    • 251
    Hello friends display says n9 on this xerox, what can I to solve it? The customer switchs on the copier without the fuser unit, and when I installed it display says n9. Thanks in advance.
  • xeroxsharp
    • Nov 2008
    • 270
    Re: xerox workcentre 5020 n9 error
    enter diag
    999/start/993/start/you will see run on CP/turn off
    • javier4065
      • Feb 2007
      • 251
      Originally posted by xeroxsharp
      enter diag
      okey friend, today I'll try it. thanks.
      • javier4065
        • Feb 2007
        • 251
        enter diag
        I tried it but the copier says n9 still , another solution thanks.
        • Blizzoo
          • Aug 2013
          • 608
          Check the thermostat if it's open.Check the wires connection in fuser section,lamps etc.Repeat the above reset procedure after inspection.
          • xeroxsharp
            • Nov 2008
            • 270
            nvm initial.
            20-58
            BR
            • javier4065
              • Feb 2007
              • 251
              [QUOTE=xeroxsharp;409541]nvm initial.
              20-58
              BR[/QUOTE=Thanks, I checked the fuser unit and all components are right, well How can I enter these diagnostics numbers 20-58 because when I 'm in diagnostic mode appears c letter then I enter 20 and start button and appears c again.only I can enter three ldigts numbers.I have a serius problem with customer.I wait for your help.
              • adriansto
                • 2388
                Why you dont buy a service manual for the machine ?
                • javier4065
                  • Feb 2007
                  • 251
                  I have the service manual and there are two options to enter service mode, But I don't find the chain to reset this error code. thanks.
                  • adriansto
                    • 2388
                    There are two options because there are two different machine.
                    One WC5020 with platen or adf and another machine with dadf.
                    N9 error code has nothing to do with the fuser. You must see the entire error code n9.xx.
                    I presume your machine is WC5020 with DADF, duplex print and scanning and you dont have the right manual for it
                    • javier4065
                      • Feb 2007
                      • 251
                      How can I know what model it is? this copier has adf. thanks.
                      • adriansto
                        • 2388
                        Read again chapter 6 from service manual
                        It's very clear explained. Check the value of nvm 50-20. Must be on 0
                        Then go an execute 20-58 for resseting nvm's
                        • ali.alhaj
                          • Mar 2013
                          • 34
                          set location 650-20 to 0.
                          • javier4065
                            • Feb 2007
                            • 251
                            <<<<<<<well, I have the same problem, I enter to service mode ,I press and hold 0 buttom for about 8 seconds then I press start buttom, display says _ _ _ I put 6,7,8,9, and press start buttom display says C _ _ but I can not input 20 - 58 when I put 20 and press start display says C _ _ again , I can input 650 then appears L _ _ then I input 20 press start buttom and display says RUN ,well What else can I do to solve this error code,thanks.Maybe change the mainboard and What is the meaning N9?
                            • ali.alhaj
                              • Mar 2013
                              • 34
                              this is normal fault error in 5020 ,this error related from fuser and the location 650-20 reset the error.thanks
