Xerox WC 4112 061-320
Re: Xerox WC 4112 061-320
If you have another Drum try replacing it. Otherwise check the Drum ground strap and the Drum ground pins.Comment
Additional things to check:
Replacement of drum crum pwb, PL11.2 item 3
Replacement of drum detect switch PL11.1 item 7
Replacement of main power switch
Replacement of front cover switch PL1.1 item 11
Check for binding of waste toner augers, it can cause your drum not fully seat even though it latches.Comment
Thanks for your help and advice guys. Turned out to be a stupid little broken wire. Don't know why it broke, no signs that it fried, running in straight path, possibly a mouse but the machine was running when it coded. Oh well thanks againComment
hi there i am facing saME PROBLEM for xerox 4112, please guide me for the broken wire you found in your machineComment
