xerox workcentre 7545 non customer mode
  • jtymabel
    • Aug 2008
    • 164
    Hello
    Having a problem with a workcentre 7545 in non customer mode. Can anybody help me with the nvm value.
  • Exok
    • Jun 2011
    • 750
    Re: xerox workcentre 7545 non customer mode
    What exactly are you asking? Do you want to know how to access service mode or do you know how and need to change an NVM setting. What is it you want to change? What NVM value do you want?
    • Exok
      • Jun 2011
      • 750
      Your original post makes as much sense as "I'm having trouble with my Ford Focus when i'm not driving it. Can anyone help me with the adjustment?"
      • jtymabel
        • Aug 2008
        • 164
        i can access service mode and i know how to write values. i just dont know what i need to change to have the work without the "machine is in non customer mode" Customer got the machine from the purchase of another business. They tried resetting the admin password and in the process wiped the nvm values.
        Whatever help you can give me will be greatly appreciated.
        • adriansto
          • 2384
          Go to WEB UI interface and read the faults code from there.
          • artur
            • Feb 2014
            • 5
            • Power down the machine, and disconnect the network cable.
            • Power on the machine.
            • If the Install Wizard appears, complete the Wizard.
            • If this does not resolve the issue, power off the machine and reconnect the network cable.
            • Power on the machine, and enter UI diagnostics (CSE mode).
            • Go to NVM location 616-014 (system install phase) and change the value to "2".
            • Exit diagnostics and reboot the machine.
            • Follow the Install Wizard to correctly set the date and time, etc.
            • If the machine hangs and won't complete the wizard, go to NVM location 616-014, and change the value to "4".
            • Enter Tools, and set Date and Time, Language, Measurement (inch or metric), and Paper Size Preference (inch or metric).
            • djwhoo
              • Aug 2013
              • 117
              Originally posted by jtymabel
              Hello
              im having the same problem.. any advice?
              • xeroxsharp
                • Nov 2008
                • 270
                Please check mashine counters status.
                If you read zero status,you will need to replace
                1-battery on flash modul of SBC
                or
                2-flash modul ( 960K73451 ) of SBC
                or
                3-even SBC
                When I have this problem,and the counters status is zero,I always replace flash modul and do an ALTBOOT,and complete the UI Wizard.
                • archybos
                  • Jan 2012
                  • 24
                  Pls i have some problem with my xerox 7545, I can't print ,it showing READY TO SCAN,COPYING AND PRINTING NOT AVAILABLE .....THE DEVICE IS A NON CUSTOMER MODE.pls what can I do to solve this problem
                  • akos
                    • Apr 2017
                    • 8
                    This notification occured when the voltage of yellow battery on nvm flash below 2,75V. In this case the couters of machine are lost. This battery orderable from Xerox, and after replace many nvm settings needed.
                    • sajo
                      Pls what are the NVM setting required to replace the Ram battery?
                      • ps22sp
                        • Aug 2014
                        • 83
                        i have xerox workcentre 7845 system error
                        press 0 10sec and then start gointo service mode
                        password 6789
                        go adjustment
                        dc131
                        input 616 014 read
                        then 2 write select reboot
                        machine restart and nostop keep restart action
                        something wrong
                        anyadvice welcome
                          password 6789
                          go adjustment
                          dc131
                          input 616 014 read
                          something wrong
                          anyadvice welcome
                          seeing how this thread is pertaining to WC 7545 and your problem isn't the same as the OP ...
                          START your own new thread.
