8825 wide format
  • walidcharifi
    • Feb 2011
    • 379
    8825 wide format
    hi friends
    i am a problem of my xerox 8825/8830
    - Background
    - toner particles on the media
    - toner particles on machine ..... photos
  • xcopytech
    • Aug 2006
    • 1794
    Re: 8825 wide format
    Do you use OEM toner?
    Go to diagnostic mode and check reading from ATC sensor.
    Maybe machine is overtoned. Adjust ATC sensor.
    Have you ever replace developer material?
    • copytech200X
      • 264
      Do ATC sensor calibration if failed below spec ,replace developer material and check drum life last change.
