xerox dc 250 nvm code 751-448 not responding
  • akshit
    • May 2014
    • 9
    i am working on two of my xerox dc 250. the nvm 751-448 set to 1 works in my one machine but it does not work on another..
    some one please help me.. as i am using no of drum crum (chip) to start the copy n print on machine...
    please help me with this problem.
    what should i do for this so that my another machine also validate the nvm for drum life which is 751-448 to 1.
    which start the print showing the message for order a new drum catrige.
  • adriansto
    • 2375
    Re: xerox dc 250 nvm code 751-448 not responding
    Probably the two machine have different software levels.
    May be if you need to have same level software for both machine
    • akshit
      • May 2014
      • 9
      adriansto :
      thanks fr the replay.
      but how i get the same levels..??
      by reseting them to factory reset..??
      • adriansto
        • 2375
        By reloading the software version on to machine who dont work 751-448
        Sent from my V3-E using Tapatalk
        • akshit
          • May 2014
          • 9
          how can i do that..??
          or ther is some other nvm value for the updated software verson..?
          • mickey singh
            • May 2014
            • 93
            What software is the machine on? Have you tried putting it back to 0, then rebooting a couple of times, setting it to 1, reboot and check, most of the time they just need a little nudge to work!
            • akshit
              • May 2014
              • 9
              yes i have tried. the machine sets the value to 1 but the printing is not on. it still display replace your drum catrige.
              while in other machine printing is on and it display just to oder a new drum catrige.
              and the machine which is not printing is running on software verson VGY 1.231.7 VERSON.
              • adriansto
                • 2375
                And what is the sw version for working machine ?
                • akshit
                  • May 2014
                  • 9
                  ITS VGY 1.231.15
                  • adriansto
                    • 2375
                    ITS VGY 1.231.15
                    Now you have the answer.
                    Upgrade the software at 231.15 on nonworking machine.
                    • xcopytech
                      • Aug 2006
                      • 1783
                      After some time chip die and you need to replace drum or chip even if nvm 751-448 is set to 1.
