102-372 on Docucolor 2240 (reinstall software)
  • Xahz
    • May 2014
    • 7
    [Error Code] 102-372 on Docucolor 2240 (reinstall software)
    I have a Docucolor 2240, but it gives me error 102-372, requests to reinstall the software. I have the firmware, the problem is that DC 2240 does not start to make the repair.
    Connect via LPT1 and I did a firmware Download, but not start, and when connected to COM1 not detected. I have the PWS running on a virtual machine (Vmware Workstation V7.1.3) with Windows XP Sp3. How I can reinstall the software?... help me
  • adriansto
    • 2385
    Re: 102-372 on Docucolor 2240 (reinstall software)
    Try to use a real WinXP with SP1
    I dont know how the pws works on a virtual XP machine.
    Your machine is old one. Find an old computer or laptop.
    • Xahz
      • May 2014
      • 7
      Although the DC 2240 don't initialize, can it be repaired?. because don't start printing mode, and the error code 102-372 directly appears and not the control panel.
      • adriansto
        • 2385
        The problem is on ess pwb or ess components.
        What version of the pws diagnostic tool do you have ?
        • Xahz
          • May 2014
          • 7
          I have PWS 9.2 non-xerox, PWS Diag 3.6 and DC2240_1632_3535_M24_eng_files
          • adriansto
            • 2385
            I dont know what ' DC2240_1632_3535_M24_eng_files ' mean but the pws 3.6 is good
            Also you can check the IOT to IIT thick cable.
            • Xahz
              • May 2014
              • 7
              I have a old machine with WInXP, but the DC2240 not initialize and can not connect via serial port, I have 9 pin to pin cable. I don't know how to initialize.
              • Xahz
                • May 2014
                • 7
                Finally I could. Just press "4 + power save + stop" and enter download mode and there upgrade firmware via LPT.
