Error DFE 006 on DC 250
  • davidj7
    • 1107
    Hi
    I am getting an error DFE 006 in command work station on a DC250. I dont have the required documentation to trouble shoot DFE. Could anyone please share this info with me.
    Now to the probem:When i turn on the printer and give a print . It process and prints the 2nd print it shows unable to find printer .Scan does not work . I am able to ping and connect via Command Workstation.
    I cleaned reinstalled the DFE software . Cleaned the RAM ,connectors etc. Any suggestions on what to do .
    a machine is only as good as your tech : source:screwtape ; the scary one
  • xcopytech
    • Aug 2006
    • 1794
    Re: Error DFE 006 on DC 250
    do you have any code on fiery led
    • adriansto
      • 2387
      What machine software version ?
      Read the 666347 bulletin from SearchLite
      • davidj7
        • 1107
        I am getting FF on the fiery LED
        adristano: No my problem is bit different from that .
        • xcopytech
          • Aug 2006
          • 1794
          • InterfaceP
            • Jun 2013
            • 488
            I think you said SW was reinstalled already. If not you need to. Other than that it could be the power supply. Sometimes the smell of burned wires is present in the power supply.
            • davidj7
              • 1107
              Yes SW was already reinstalled twice. I will recheck the power supply . Thank you
