DOCUCOLOR 240 how to clear 042-326 code?
  • chrisp
    #16
    drum reset document centre & Apeosport.
    Hi.
    I often cover remote areas and as such I have to deal with many brands that I am often not completely familiar with, Often in such cases it would be benificial to have a code to get a xerox machine going until I can send or return with a new drum . Can you please give me the NVM code and reset proceedure for the models you know. Thank you so much.
    Regards ChrisP
    • chrisp
      #17
      Its OK I found this setting NVM 751-448 SET TO 1 continues copying but warns drum needs replacement now.
      • lscheres
        • 11
        #18
        Belt keeps moving????`
        Ok im getting a little irritated with this thing. First off im trying to run a 10 pages book 11x17 folded stapled, Its on 70lb Titan gloss, I keep getting jams 077-130 Duplex out sensor on jam and 077-118 Duplex feed pre regi sensor on jam. Ive cleaned the whole machine ,and wiped the paper path with some solution that helps with the static issues because that was what i thought was causing it being gloss, Ive also clean all the rollers with rubber roller rejuvenate stuff. Still jams. And now to add to the whole thing my ibt belt keeps moving of center and i cant figure out why. Ive check everything on it and cleaned the cleaning assembly and the reflective patch is still reflective. But after like 100 books i get the 042-326 error and have to recenter my belt. I HAVE to have this job done tonight, well and i still have roughly 300-400 books to go and its been 3 days of all nighters for me and im running to the end of my rope lol. Any help will be greatly appreciated. Thanks Copytechnet Gurus!!!!
        • lscheres
          • 11
          #19
          lol forgot to mention its a xerox dc250 with a booklet finisher. And im currently running, just very slow and unproductive lol. Again thanks for any advice ill be checking back like every half hour
          • Onetouch
            • May 2008
            • 62
            #20
            Xerox DC 240 BK Drum
            I have a customer who has Xerox DC 240. The machine had little black spot on BK drum. I have changed 4 brand new Black drum now but I still keep geting those little black spot on drum after I copy about 200 to 300 copies. I can see those spot on my printed pages. Any idea how to stop getting my BK drum dameged.
            Sounds weird but I hope it make sense to you guys.
            Thank you.
            • dsmorgan
              #21
              Re: DOCUCOLOR 240 how to clear 042-326 code?
              PLease could someone explain where the transmission belt is on the Docucolor 240. Thanks.
              • TechMate
                • Mar 2008
                • 285
                #22
                when you open the front door, there are 3 drawers. the first is the developer-drum drawer. the second is the IBT assembly drawer, and the third (with a green lever) is the registration-2ndBTR-fuser drawer.
                You will need to remove 2 screws on both ends of the 2nd drawer. make sure u unlatch the lever of the 1st drawer b4 pulling the 2nd & 3rd drawers in order to see the IBT assembly (on the 2nd drawer). Then you will find the IBT belt (black)
                • adriansto
                  • 2388
                  #23
                  To be most understood
                  • ernfuggit
                    #24
                    Hello all. I am extremely new to all this. We just recently got a DC 240. I got the 042-326 error this morning. After a ton of research, I finally have the IBT assy out. Where is the reflective strip located? I do not see it?
                    • saga710
                      • Jul 2011
                      • 6
                      #25
                      Do the following carefully:
                      Remove screws marked in red circles.
                      Turn Clockwise with 5.5 mm screwdriver ( blue square mark ) these release IBT
                      At the bottom of the IBT is the reflective square, you can replace it with reflective material or clean it.
                      • ernfuggit
                        #26
                        Thanks for your reply. I will try this today!
                        • Paula
                          • Jan 2013
                          • 14
                          #27
                          I have the same error.
                          The information posted so far is very helpful, although I can't see how to extend the drawer out far enough to reach the rear handle of the IBT.
                          Please help.
                          • Paula
                            • Jan 2013
                            • 14
                            #28
                            It's open
                            Can you please advise the location of the Sensor? The belt is out.
                            • saga710
                              • Jul 2011
                              • 6
                              #29
                              Please help.
                              Please check: on youtube to see how to extend the drawer.
                              • Paula
                                • Jan 2013
                                • 14
                                #30
                                Thank you so much!
                                I am going to do this right now
