DC242 - 300gsm jamming in fuser
  • steveclv
    • May 2014
    • 95
    I am trying to run 300gsm gloss through the DC242 but each sheet is jamming at the fuser - I have it set to Heavyweight 3 through the bypass tray (5).
    Can anyone point me to where the problem might lie?
    I tried 200gsm and it did the same.
    Steve
  • steveclv
    • May 2014
    • 95
    Re: DC242 - 300gsm jamming in fuser
    OK, I just did some more testing and it's running fine on A3 but it's jamming on SRA3 - any paper weight
    Any thoughts?
    Steve
    • azehnali
      • Nov 2009
      • 679
      changing the fuser would be a good start !!!!!!!!!!!!!
      • steveclv
        • May 2014
        • 95
        OK, I'll give that a try
        I was just wondering if this was a known or common problem that might have an easy fix - the fuser is working just great on other sizes - A3, A4.
        I'll order a new one though.
        • imihm
          • Feb 2014
          • 77
          Steve
          Hi
          Try to adjust the fuser nip
          • steveclv
            • May 2014
            • 95
            Originally posted by imihm
            Hi
            OK, I'll check the eDocs for the procedure unless you know it - it does appear that it's the far side that catches rather than the side closest to the door. I'll order a spare anyway but if I can save this one then that will be a bonus
            Thanks!
            • ramyaselvam
              • Jan 2013
              • 6
              Thanks!
              in the fuser assembly above the fuser roller there is a plate with adjustable screws (4 or 5). it adjust the space between the fuser roller and the plate. if the space is high the paper or boards definately jam
              • steveclv
                • May 2014
                • 95
                Is that the 2 adjustable screws - on on either side? There is a spring in the screw assembly too? I can try adjusting that and see what happens, making a note of the settings first.
