Fiery EX260 thinks it's connected to a DC250 but it's a DC242 - how to fix?
  • steveclv
    • May 2014
    • 95
    I have a used DC242 and a used Fiery EX260 which I suspect came from different sources (from a used copier sales warehouse).
    Is there a way to configure the Fiery to tell it that it's connected to a 242?
    Is there any difference between a DC250 and a DC242 when managing it through the Fiery?
    Thanks for any help.
  • InterfaceP
    • Jun 2013
    • 488
    Re: Fiery EX260 thinks it's connected to a DC250 but it's a DC242 - how to fix?
    EX260 is for use on a DC242/252/260. It wont work on a 240/250 that would be an EXP250
    • steveclv
      • May 2014
      • 95
      Well it's definitely an EX260 - says so on the splash screen - but the model is identified as a DC250
      Strange....
      • InterfaceP
        • Jun 2013
        • 488
        What says DC250? The printer? Look at the SN inside the left side door if it starts with DUX it's either a 242 or 252. VGW indicates a 240 or 250.
        Hope this helps..
        • steveclv
          • May 2014
          • 95
          No, the printer is a 242 as it says so everywhere
          When I boot up the Fiery and run CWS it tells me it is connected to a DC250 and the printer is shown in the interface as being a 250.
          I don't know if it makes any difference - it's just a little annoying.
          Does anyone else have an EX260 and does it show the correct printer attached?
          • InterfaceP
            • Jun 2013
            • 488
            That's simply the printers designation in CWS. I believe you can change it but it's more work than it's worth.
            • steveclv
              • May 2014
              • 95
              Thanks - that's kinda what I thought as it all seems to work just fine - I just wondered if setting it 'correctly' would release some magic fairy dust
