Xerox sent WC7125 MCU (101K61942) instead of WC7225 (101k61941)
  • axyun
    • Aug 2007
    • 1323
    Xerox appears to have sent WC7125 MCU board instead of WC7225 board w=hic I ordered. I have SM and was careful to order correct part. The p404 connector on board has only 8 pins on the board they sent while the correct board has 11 pins on P404 connector. Also 2 pin connector P427 is not on board sent though i did not check to see if it is used. Please advise if these boards are interchangeable with an adaptor connector. Frank/ActionPhotocopy
  • adriansto
    • 2388
    Re: Xerox sent WC7125 MCU (101K61942) instead of WC7225 (101k61941)
    101K62800 is the pn for 7225 MCU
    • axyun
      • Aug 2007
      • 1323
      You are right Adrian. The part number I gave is for the board with the holding bracket. The Xerox WC7220/7225 service manual is not showing the part number of the board but of the board with bracket which is 101K61941. It is on page 5.65 of parts list section. Frank
