I have a DC242 and an EX260 Fiery - it was working OK until this afternoon.
I sent an job to the Fiery through CWS and it went to the Fiery OK. It ripped OK and then went to the printer - I then got a Blue Screen with a Memory Parity Error and the DC242 showed an error with the Network Communication (I forget the exact code)
I reset the cable between the Fiery and the DC242 and retested - same problem - ripped ok and then failed when it went to print
I tried again with a different (smaller) print job - same issue.
Using the Fiery Bar, I ran the Diagnostics and tested the I/F board and it came back with Video Diags Failed (System ID ffffff)
Does anyone have any idea what to try next to fix it? I have rebooted and restarted both the Fiery and DC242 several times. The DC242 copies fine from the glass.
I'd really appreciate any help anyone can offer.
