good day, xerox workcentre 7775, getting a color drum r2 error, call for assistance, went into the diagnostic mode, but there were no error codes showing what exactly is wrong. Any suggestions?
Color Drum R2 Error, call for assistance
Tags: None
Re: Color Drum R2 Error, call for assistance
awesome, thought of that. And if the error still says r2 what would that mean?Comment
It's the drum moved it now error on #3. Thanks will replaceComment
If the defective drum is new enough you may be able to fix it by just replacing the RF CRUM chip located inside the drum's front cover (1 screw). The part # i use for the color drums is DC250CNC (for the 3 color drums) and DC250CNB (for the black drum). You can also use these replaceable CRUM chips to extend the life of the drums to save money. They might not last 200% of recommended life but you can pull that CRUM out of the drum before you throw it away and then use it on the next drum when it gets to 0% to extend the life of the next one.Comment
