004-347 After belt replacment
  • bmt_hr
    • Mar 2011
    • 128
    [Error Code] 004-347 After belt replacment
    Hi
    After transfer belt replace I have that error code 004-347 !!!?!!!
    Machine is WC 7346..
    thanks
    br
  • adriansto
    • 2388
    Re: 004-347 After belt replacment
    Originally posted by bmt_hr
    Hi
    thanks
    br
    Check again how the belt was installed especialy belt edge sensor and belt tensioners.
    • bmt_hr
      • Mar 2011
      • 128
      Edge sensor is ok postion (when I make few color copies then he make error), but what is the belt tensioners?
      • adriansto
        • 2388
        The elements who make the belt to be stretched.
        • bmt_hr
          • Mar 2011
          • 128
          My problem still stands on that machine. Check it all, but I can no longer find fault ..
          • Exok
            • Jun 2011
            • 750
            This error indicated that the IBT edge sensor does not detect that the Transfer Belt edge is in the correct position.
            If this error was not present prior to replacement of the current Transfer Belt:
            Remove the IBT belt assembly.
            Locate the IBT edge sensor and make sure it is connected and clean.
            Release the belt tension.
            Make sure the belt is perfectly centered on its rollers. (same distance away from the front and rear of rollers it is mounted on)
            Reapply the belt tension.
            Reinstall the IBT assembly.
