Xerox Colorcube 8900s Password reset
  • toperu
    • Jul 2025
    I need to reset the admin password for my colorqube 8900s. I changed the original 1111 password and my new password was working fine for months. Had a computer crash and reinstalled my windows. after doing so, when i go to the Centreware internet page I cannot login. It does not accept the password now. I cannot attempt to login at the control panel as that function was disabled. thus, I'm stuck. I saw on this forum a mention of a reset tool regarding the 8900x. Can anyone help me with this?
    Thank you in advance.
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox Colorcube 8900s Password reset
    CE password is 1991
    [*] [#] [Stop]
    You may be able to change it from there, I'm not sure though.
    • adriansto
      • 2387
      Send me mail at stoadis@gmail.com with serial number and total meter of the machine and I will generate the reset code for you.
      • toperu
        Originally posted by InterfaceP
        CE password is 1991[*] [#] [Stop]
        When you say CE password is 1991, to what are you referring?
        The control panel on the machine gives me no options to enter the security settings to reset or change. Any panel access was disabled when the machine was delivered and unfortunately I did not see a need at the time to enable them via the web interface, thus the web interface is all I have unless there are some specific key sequences on the panel that allow me to gain access and reset the password.
        thanks for responding.
        • InterfaceP
          • Jun 2013
          • 488
          Try Adriansto's method first.
          Otherwise CE= Maintenance/Diagnostics Press * # then Stop enter the password. You may be able to reset from there.
          • toperu
            Problem Resolved. Adriansto had the software to generate the reset code. thanks again for the help to all posters.
            • superdesi
              toperu,
              where did you enter this code? I have the same machine and the same problem.
              thanks.
              • Lucky22
                • Jun 2014
                • 2
                Hi,
                Can anyone help me with password removal from my Xerox Colorcube 8900?
                Serial Number: 3271306899
                Total Impressions: 19646
                My machine can copy and scan only
                also, the color printing is disabled.
                I tried "admin" and "1111" but it doesn't work.
                I can't understand why Xerox support doesn't want to help me...
                they are pretending that "Visit of a technican is required" which cost a fortune in my Country.
                So, could somebody generate that password for me please?
                I know the proceure:
                "At the Touch User Interface, hold down these 3 keys in this order: Star * then 3 then
                the numeric clear C key.
                Star * then 3 then the numeric clear C key.
                The Login screen should appear.
                Enter the 12 digit Reset Code obtained..."
                • saraint
                  HI
                  I bouth XEROX ColorQube 8900S
                  some time ago other admin, change a admin password on it.
                  hi is no work anymore with me, and I can not do any config
                  can you help me to reset my admin pass Please?
                  my serial is 3271266927
                  and total impresions 117,901
                  regards
                  Martin
